3-Newcomer
Parameters for individual Parts when multiple are used in the same drawing
So I have multiple models in a single drawing, if I just select "&view_scale" it pulls the parameter from I'm not certain.  But IIRC there is a way to select the ID number for the individual component and pull up what that parameter is.
I want to say I used this successfully many years back in a large assembly and/or family table.  Any help would be greatly appreciated.   Please see the image for reference.
mkajdan
mkajdanAnswer
These images are with the assembly open.
kdirth
If you set the scale in the view properties and not follow the sheet scale, even if the same. Creo will create the note for the view.
3-Newcomer
OK sure but let's forget the note.  I'm not trying to only show the scale of 1 component.  There is a feature in CREO Parametric that allows you to do as I described above - find an ID number associated with the parameters of components in an assembly drawing, or more specially in my case the parameters of individual parts when a drawing has several models associated with it.
kdirth
The question of "where does it pull the parameter from?" is the active model in the tree.
Select view > RMB > Use Model in Tree
The model of that view will now be active in the model tree.  You can add a parameter to a note and Creo will add the appropriate session ID to it.
