2-Explorer
February 19, 2019
Parameters update sequence in assembly
  • February 19, 2019
  • 11 replies
  • 4701 views
Hello
We have master assembly and it has 7 parts... We are trying to achieve parametric model for same.
Query is that what could be the better sequence to update parameters into assembly? Let me try to elaborate a bit.
Assembly a.asm has 7 parts assembled as part1.prt to part7.prt... There are few parameters which need to be updated for a assembly and parts.. what could be better sequence to update parameters...? One should update it as first from parameters of last part part7.prt and gradually moving towards part1.prt and at last parameters of a.asm....? Is this better sequence to update parameters into assembly or something else should be followed ?
Additionally within part also , parameters affecting last most features should be updated first compared to parameters affecting top most features.. is this a good practice?
Feel free to ask for any clarification in case of any confusion.
Thanks and Regards
Ketan
Mahesh_Sharma
22-Sapphire I
February 20, 2019
@Ketan_Lalcheta
If there are no relation in parameters of part and assembly, I think it should not matter which parameters are updating first..
2-Explorer
February 21, 2019
Hi
Parameters are used in relation and pro program.. within part, parameters can show hide features and updates feature dimensions also
Thanks and Regards
Ketan
HamsterNL
18-Opal
February 27, 2019
Are you using EXECUTE statements?
