PARAMETRIC UDF
- April 25, 2019
- 6 replies
- 3406 views
I am trying to create a parametric udf consisting of a tool no. and that tool no. has to be in an oval shaped box as shown.
The problem is that, if i change the tool number value, the oval shaped box gets cancelled.
Is there some way in which I can automatically change the the box dimensions whenever the parametric udf text increases.
In short is there any way in which i can make the box length dependent on the udf text length?
I tried using relations but could not get it.
