Part Feature error
Error with existing part features when adding or modifying a part feature:
After adding (or modifying a part feature), all existing part features come up in error (within said part). When you select the feature in error (i.e. edit definition), nothing appears out of place and by simply executing an update corrects the feature in error. Problem is that you have to visit every feature until the part is completely rectified. We are running Creo 2.0 data code M120. Any suggeations?
