Pattern
- January 10, 2013
- 13 replies
- 6082 views
OK, here's the pattern (image attached) - a revolved spherical dimple on a revolved non cylindrical surface. I want the dimple patterned in two directions - very approximately a cylindrical grid - around the revolved surface and along the surface. Easy enough on a true cylinder but keeping the dimple following the curved surface is the tricky bit,
cheers, Sean
