8-Gravel
Pattern a hole on a cone surface normal to the surface
Is it possible to pattern a hole on a surface that is cone shaped, the direction of the holes must be normal to the surface. In solidworks this was very easy using a 3D sketch
tbraxton
Yes, it is possible.
Generally, you would create a group of features.
1) Point on cone surface
2) Axis through point, normal to cone surface
3) Coaxial hole
Consider using a reference pattern to save on regeneration overhead where possible.
Refer to this thread for examples of holes normal to surface that are patterned. Take a look at the part models and links posted. Your problem is a subset of what is discussed here but it will provide insight into what is possible in Creo and how to create the features.
Solved: Reduce to practice a variable axial pattern - PTC Community
8-Gravel
the surface is not an actual cone but if i try the geometry pattern the axis are paralell, the refference pantern stays greyd out
tbraxton
The general method I posted above should work regardless of the topology of the surface (assuming Creo can determine a surface normal of the surface). Without more detail on exactly what you are working with it is hard to make suggestions. Post a picture or ideally a simplified test case model. I can only work with up to Creo 9 at the moment.
