Pattern-sketch on sweep
  • February 14, 2016
  • 2 replies
  • 2782 views
‌Hi
using CREO2, I'd like to manage a dynamic sketch inside a sweep.
Based on parameters, I'd need to obtain a sweep section with one ,
two, three or more circles with regular distance around a centre
( like a pattern feature based on axis).
Any ideas ?
thanks in advance.
Pier
Something like a variable section sweep?  Many ways to drive a dynamic sketch for precise control.
I think they are saying they need to vary the number of circles swept, which becomes more challenging than varying dims within a singular sketch.
Ah, that makes sense now... Then I would pattern the sweep using pattern table variables for the angle, radius, and quantity.  Values can be derived from input.
Hi
let me try to explain.
I have a sweep trajectory that is a complex 3D Curve .
As internal section I could have one or more circle . This geometry is driven by some relations (circle diameters, quantity , ...)
It's not possible to create a pattern of single sweep feature ( the trajectory is not linear ) .
A reference model is a rope with groups of wire inside.
many thanks
Pier
what is the purpose of such model ?
MH
