patterning a surface merge...
Greetings,
I know that I have reference patterned a surface merge before. What a time saver that was. However, I am not able to do it in my current model for some reason. Any hints as to what I might be doing wrong? The surfs are extrudes, patterned along a curve and they touch at a tangency. A single merge from the leader to the second extrude works (and that one to the third, etc...) but, the Reference pattern option is grayed out. I also tried creating a "connector" surf to merge to, but the ref pattern does not work with that either.
Any hints?
Oh - I am running WF2 for this job.
Any hints?
