PCF options
  • July 16, 2015
  • 12 replies
  • 7164 views
We are having an issue when printing to a specific printer the prints are pushed all the was to the bottom right and it is cutting off some of the information for the drawing. Is there an option in the PCF file for the printer where it would force it to center on the page? This is an OCE TDS600 plotter. Using Creo 2.0 M160.
Best answer by jweaver
User began using Creo print manager and that seems to resolve the issue. Might be a problem with Windows settings for the printer.
Justin,
there are options for defining x-offset and y-offset, only.
Martin Hanak
jweaver1-VisitorAuthor
I feel like you shouldn't have to use offsets and the printer should realize that it should be printing all the information on the drawing. We aren't having any issues with any of the other printers and they don't have offset settings either. Below is what is in the PCF file now.
plotter OCE9600
button_name TDS600
button_help TDS600 on PrintServer
delete_after_plotting yes
plot_drawing_format YES default
plot_segmented NO default
plot_roll_media YES default
plot_label NO default
plot_handshake software default
create_separate_files NO default
plot_with_panzoom yes default
rotate_plotting NO default
allow_file_naming YES
plot_name NO
interface_quality 3 default
plot_destination printer default
plotter_command windows_print_manager \\PrintServer\Oce TDS600
plot_file_dir C:\temp\
pen_table_file table.pnt
plot_sheets current default
!paper_size d default
paper_size_allowed c d e f
paper_outline NO default
plot_clip NO default
plot_area NO default
plot_stroke_text YES
Justin,
I guess that:
1.]
if you print C size drawing to C size paper then the problem appears
2.]
if you print C size drawing to D size paper then the problem disappears
If the above guess is correct then you have to use plot_translate option inside pcf file, eg.:
plot_translate 20 20 MM default
Note: I had to use plot_translate option in the past for plotter DESIGNJET
Martin Hanák
We are using OCE TDS-700 plotter and this is our PCF config file:
plotter DESIGNJET755CM
button_name OCE_TDS-700
button_help Print using OCE_TDS-700.
interface_quality 2
paper_outline NO
paper_size_allowed A0 A1 A2 A3 A4
pen_table_file plot.pnt
plot_area NO
plot_clip NO
plot_destination file
plot_file_dir $userprofile
plot_label NO
plot_names NO
plot_roll_media YES
plot_segmented NO
plot_sheets current
plot_with_panzoom YES
rotate_plotting NO
Note that Creo does not use second option word anymore, e.g. plot_segmented NO default, so you may omit that to avoid any missreadings in Creo.
Also note, that when you use rolls of paper with exact width of the standard paper size e.g. 594mm for A1, you need to check the Creo formats for the outer limit of the format being equal or less than 594mm otherwise plot origin will be shifted and/or plotfile rotated on the plotter to try to fit the paper size, thus part of plots will be cropped.
Anyway, we have found out that plots are made as good as directly plotted to plotfile when we export to PDF and plot them on the same plotter. The advantage is that you can open and review PDF before plotting whereas plotfile is useless in that respect.
I have come to find out that the issue is only happening when using Windows Print Manager. If you select the plotter right from the Creo print manager it is fine. I believe that means that the PCF file is OK and the setting needs adjusted in Windows. Am I correct on that?
Not necessarily.  Each printer will generally have it's own PCF file.
Yes, but if you select the MS print manager from the list in Creo, then select the printer as if your printing from any Windows application, doesn't that use whatever settings you have set in the Windows properties, and doesn't use the PCF for that printer?
jweaver1-VisitorAuthorAnswer
22-Sapphire I
August 10, 2015
I spent considerable time / effort on this with multiple companies.  Came to the conclusion that in general, it's better to get Print to PDF working from Creo, then have all users print from PDF.  There are some legitimate reasons to print directly from Creo but they are getting fewer all the time.
