PDF Setting for Eng Drw and pen tables
  • December 8, 2010
  • 775 views
WF5 M040
Publish > PDF > Settings
Have can I control the line weight of the PDF output? Is it in Drawing Options or is it controlled by the Pen Table referred to in the settings? If so;
- what form does it take?
- where should it reside?
- do I need to refer to it in my config?
I currently reverting to using Adobe distiller as it gives a better output than the embedded publisher but it is more of a faff,
Cheers, Sean
pdf_use_pentable == yes
pen_table_file: Specifiy the full file path to "pdf_pen_table.pnt".
I have attached the pen table file I use. Open with notepad and tweek as needed for your purposes.
