pfcDetailNoteInstructions - TextHeight
  • December 13, 2013
  • 5 replies
  • 2761 views
Hi there,
I am trying to modify the text height of a table note.
What works right now is this:
var xyz = table.GetCellNote(cell);
var new_text_format = xyz.GetInstructions(false);
new_text_format.TextAngle = 12;
xyz.Modify(new_text_format);
But I want to modify the text's height not its angle.
Any suggestions?
    Best answer by jnezu
    Hello MATTHIAS
    Did you already solve this problem.
    Textheight of Detail note is a little bit complicated because textheight can be set by both each line and each segment of a line.
    if you wanna set all texts to same height, the code will be like the following
    var drawing = session.CurrentModel;
    var matrix = drawing.GetSheetTransform(drawing.CurrentSheetNumber).Matrix;
    var new_text_lines=new_text_format.textLines;
    for(var i=0;i<new_text_lines;i++)
    var new_text_line=new_text_lines.item(i);
    var new_texts=new_text_line.texts;
    for(var j=0;j<new_texts.count;j++)
    var new_text=new_texts.item(j);
    new_text.TextHeight=12/matrix.Item(0, 0);//<-need to transform the coordinates
    jnezu7-BedrockAnswer
    7-Bedrock
    March 10, 2014
    Hello MATTHIAS
    Mat16-PearlAuthor
    Hi Jun,
    thanks for answering. I almost gave up hope solving this problem.
    I will give it a try as soon as I have some spare time to work on it. Maybe by the end of this week.
    Thanks a lot again.
    Mat16-PearlAuthor
    OK, I was too curious, if this really would work.
    And it does!!
    After some tweaks:
    var drawing = oSession.CurrentModel;
    var tables = drawing.ListTables();
    var table = tables.Item(0); // just uses first table
    var cell = pfcCreate("pfcTableCell").Create(2, 1); // this depends on the cell you like to modify
    var new_text_lines=new_text_format.TextLines;
    for(var i=0;i<new_text_lines.Count;i++)
    var new_text_line=new_text_lines.Item(i);
    var new_texts=new_text_line.Texts;
    for(var j=0;j<new_texts.Count;j++)
    var new_text=new_texts.Item(j);
    new_text.TextHeight=12/(matrix.Item(0, 0));//<-need to transform the coordinates
    oSession.CurrentWindow.Repaint();
    drawing.Regenerate();
    But, could You explain this transformation (matrix.Item(0,0))?
