Please help, unable to fix or unfix record or index
Pro Gurus,
After removing a omponent was removed from the assembly, a flexible
component spring compression FN is changed from 20 to 10.
1. When I try to fix the record #10 to 20 Pro/E prompt "Can not fix index
for this record. Select record again."
2. If I try to unfix the record #10, I receive a message "The index of
this record is not fixed. Select again."
3. If I try to unfix the index #10 or #20, I receive a message "Index 10
or 20 is not fixed in this region. Enter another index..."
I try to unfix the region, redo the "fix index" from scratch and encounter
the same problem when it comes to the same flexible spring compression.
Does anyone have an idea what the problem is and can this be fixed?
Thanks in advance for any help.
Frank.
Frank.
