Plotting with Wildfire 4.0 in windows 7
Is it me or does anyone else get a problem when using wildfire 4.0 on a win7 machine where the plot's come out with no words or text, but the boarder, and assembly print flawlessly? And is there a solution?
I've tried every setting possible (probably not every combination) and no results whatsoever.
I have a work-around but it provides unacceptable quality prints. (save as a tiff or pdf and then print, that works OK but the text is non-uniform and if it gets converted to pdf format text displays wrong and does not adhere to the code we use.)
