Plus/Minus dims - Possible bug?
  • August 8, 2011
  • 11 replies
  • 3952 views
Disclaimer 1: I do not create that many drawings any longer. Most of of the work I do is Class A and organic surfacing projects.
However,I havehad an atypical amount of 2D work in the past month or so. While creating dims in WF5, I noticed that clicking the plus/minus button brings up the expected X.XX +.00 (superscript) and -.00 (subscript). All is right with the world.
However, the fun begins when I change the values for the plus and minus, especially the minus. If I do not explicitly type in the "-" (minus symbol),Pro adds a"+" inthe lower limit. So my dimension would look like: X.XX +.01 (superscript) +.01 (subscript).
To my knowledge there is never a case in ANSIwhere the plus/minus would/could both be a plus tolerance. This never is the case correct? Is this a programming oversight or is Pro allowing an allowable ANSI callout?
I think the issue is not the need for +/+ or -/- tolerances. Pro/E has always had the capability to do this and there are valid reasons why. What has changed is the default behavior when you enter a value for the minus tol. In the past, Pro/E assumed that this would be a negative value and if you input a positive value it displayed as a negative. To get it to display as positive you had to input a negative value. This was perhaps a bit illogical to the programner but entirely logical to the user who will want the lower value to be negatinge 99.9% of the time. Somehow, PTC has flipped this behavior, requiring the user to enter a negative value to get a negative display. This is going to cause a great deal of confusion and drawing errors. PCT should go back to the old behavior ASAP. I for one would never put into production use software that is behaving as the original poster says it it is doing now. (FWIW, I always stay several releases behind because of PTC's abismal record of fixing one bug and creating 2 new ones.)
So you had a solution that satisfied the 99.9% case and you blew it.
In Reply to Raphael Nascimento:
Hi everybody.
Just wanted to chime in on this thread...
I think this change was made a little bit before I took over the
drawings area, but I believe the reason was to support the use cases
already mentioned by others for when +/+ or -/- tolerances might be
needed. Although they are somewhat rare, we do need to provide some
support.
So, from a functionality point of view we need to provide the ability
for +/+ or -/- tolerances, but from a usability point of view forcing
the user to type in the minus sign to get the 90% case isn't, in fact,
all that usable. One of the things we're considering for the future is a
smarter way of doing things that satisfies the 90% case with minimal
effort, but still provides the option to achieve the 10% case. Hopefully
we can sort this out in an upcoming release.
Raphael
http://www.ptc.com
Raphael Nascimento
Product Manager
T 781.370.5916
E -
PTC.com http://www.ptc.com
