Points on a surface
- September 25, 2012
- 5 replies
- 3075 views
I am trying to create spaced points on a complex surface quilt (rear car window). They need to be spaced 1.25" horizontally and 2" vertically covering the entire quilt. First I created a point on the surface dinmension to a vertical center datum plane and a horizontal plane at the bottom of the quilt. I patterned that point with 6 instances vertically and 9 instances horizontally to get a 10" X 10" square of points. I then wanted to create a fill pattern of my first pattern to spread the points over the entire quilt. This is not working partly because the fill pattern will only space the points with a single value for vertical and horazontal. I've attached the part for reference. Does anyone know of a way I can accomplish my goal?
P.S. I am using Creo 1.0
