Possible to add radius to sheet metal bend note?
  • April 24, 2013
  • 3 replies
  • 2634 views
Hi, quick question from sheet metal newbie:
Is it possible to add the bend radius to the sheet metal bend note, if so how? And is it possible to automate the process?
regards, audun
Hello
I have just posted exact same question here, but not answered yet. Wondering if you have found solution?
Regards
Andy
Mahesh_Sharma
22-Sapphire I
June 13, 2014
Audun,
You may try config option smt_bend_notes_order with value as &type&direction&angle R&SMT_DFLT_BEND_RADIUS
"R" is to show radius for &SMT_DFLT_BEND_RADIUS
7-Bedrock
October 2, 2014
Hi Audun,
starting from Creo 3, it will be possible to add &inner_radius and &outer_radius to the smt_bend_notes_order config to add the actual inner & outer bend radius of the bend.
