Preparing for introduction of PDM/PLM system (part I, duplicates)
We are preparing for the introduction of a PLM/PDM system.
Our directory based "vault" was investigated and, as expected, there are "some" problems
One of them being duplicates.
Instances from family tables were saved as a individual model file.
Also the opposite occured, inidividual models were also added in family tables.
I recently have been put in charge of (garbage, coming to america) removal of the duplicates.
First thing I did put those duplicates outside the scope of the search-path.
Next step is to identify which assembly contains an instance and which contains the individual part-file.
If I remember things well from way back when there wasn't a bytecount in the model files
internally
family table items are referenced like "3 3 instance<generic>"
individual files are referenced like "3 3 modelname"
For my investigation I'm using a DOS fgrep and a windows grep to identify
which assemblies refer to the individual file
I've created a dos batch file that does this for all found duplicates
fgrep -r -n -x "3 3 800100030" d:\prosrv\rel > c:\temp\800100030.txt
basically what this does is
list all files that contain a string "3 3 model-name"
recurse through directory d:\prosrv\rel
redirect output to file model-name.txt
This fgrep does not see the difference between "3 3 instance<generic>" and "3 3 modelname"
nor does it allow me to specify where the search string should be located in the line.
The windows grep allows me to specify that the search-string need to be at the beginning and the end of a line
but only allows me to search for a single string at the time
So both methods have their pro and cons
Having identified which assemblies I need to have a look at and
having the duplicates removed from the search-scope
I noticed that all the assemblies open properly and that they al of a sudden refer to object from family table.
I opened and saved an assembly and noticed (wordpad) that the internal notation of the duplicated individual partfile
changed from
"3 3 modelname" to
Question :
Is pro capable of switching from individual partfile to instances from a family table ?
Does my memory still serve me well about the internal model notation
3 3 modelname
Are there other mehods of investigating what I'm trying to achieve here ?
internally
changed from
"3 3 modelname" to
Question :
3 3 modelname
