Prescribed temperature to a beam element
  • June 7, 2017
  • 1131 views
is possible to assign to a beam element a prescribed temperature load in thermal mode? This beam was created by selecting a point and selecting a surface projection, not by selecting a line.
The prescribed temperature has to be applied to the underlying geometry you built your beams on.
  • Point
  • curve
  • surface
In your case you have points. You have to choose a point. You cannot apply it to the element in any other way.
