Pro/PIPING flexible parameters in a pipeline fitting
  • November 14, 2018
  • 16 replies
  • 9020 views
(Creo 1.0)
Does anybody know how to change predefined flexible parameter values on a pipeline fitting? Ex.: I inserted a 90 degree elbow fitting on a pipeline corner, setting flexible parameter values when I inserted the part. Now I want to go back and change those parameter values. The only option I see is "Remove Var Items". Do I have to remove them all and re-set them all every time? Using "Edit Definition" doesn't work, as it only brings up the fitting insertion menu.
StephenW
I don't think this is specific to piping, this is simply flexible components, right?
If so, you go to EDIT DEFINITION and then the FLEXIBILITY tab, then VARIED ITEMS under the component placement dialog to access the variable dimesion(s).
cwilkes1-VisitorAuthor
That's the problem. When you go to "Edit Definition" in Pro/PIPING, it doesn't give you the normal edit definition options. It comes up with one of those small option windows on the side. And some fittings (especially End fittings) don't do anything when you click Edit Definition.
StephenW
Try exiting the piping module then edit definition on the fitting.
It's been a while since I have used piping so I may be completely wrong.
Why is there never anybody from PTC in these forums to answer basic questions? Seriously, what do these maintenance fees even pay for?
StephenW
This community is NOT PTC support. Mostly just other users helping out.
File a support ticket at  https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log#
The problem is paying thousands of dollars a year just so they can answer a simple question once every couple years about features that are conspicuously missing from their software that should be pretty simple to find. Oh and I get to download the newest buggy, crash-prone version of their software every year HOORAY.
