Problem Loading STEP File
- April 10, 2012
- 6 replies
- 6133 views
I'm not sure if this is the right place to post this. Is there a public bug tracker for Creo Elements/Direct?
I've generated a solid elliptical cylinder with PTC's GRANITE that Creo Elements/Direct cannot import. I've contacted PTC GRANITE support and they have asked me to report this problem to Creo Elements/Direct. Am I in the right place?
When you import the attached STEP file, Creo reports a corrupt part and the display shows only error mesages (like "edge doesn't lie on face but it should"). Other software (like Autodesk Inventor) can import the file without errors.
Cory
