Problem removing a component from an assembly step in Process Plan [Creo 2]
We are using Creo 2, we have a product which has a drawing based upon a process plan assembly.
Normal assembly: A1.asm
Process Plan Assembly: P1.asm (calls up A1.asm)
Drawing: D1.dwg (refers to P1.asm)
the process plan has 9 steps.
I need to remove some components from Step 3 in the P1.asm and from the main assembly A1.asm, these components have the added complication that they are patterned components.
I open the P1.asm and redefine the step. This happens fine. Regen shows the parts removed from the step. They are not used in any other step.
The problem occurs when I then open the drawing, it crashes Creo even if I leave the parts in A1.asm (just remove them from STEP 3 in P1.asm).
Can't figure out what I'm missing here.
any help?
Precise process:
Play step > select step 3
Sequence > redefine > step 3
Components > Define > Unselect
Unselect relevant components including any parts referencing it
Regen the model, no regen errors
Open drawing > Creo crashes.
