Problem with jumper wire in NWF (neutral wire file) in WF4
How should a jumper wire in a connector be formated in a NWF? WF4 tells me that the same wire cannot be routed to the same entry port. For every other wire in the wirelist one round designated entry port works find when autorouting, but the jumper wire fails. This is my NWF format for the jumper wire (this format works for every other wire):
NEW CONNECTOR +CIT-RKS2
PARAMETER MODEL_NAME 16087-C
PARAMETER REF_DES +CIT-RKS2
PARAMETER NUM_OF_PINS 1
PARAMETER ENTRY_PORT ENTRY1
PARAMTER GROUPING ROUND
NEW WIRE W7-1_BLK18 18BLK
ATTACH +CIT-RKS2 " " +CIT-RKS2 " "
Its seems as if I need a mutiple entry port format of some sort.
