Problem with viewable creation in Schematics
  • March 27, 2015
  • 1344 views
Sorry if you are seeing this a second time. I just don't know where I should post this one.
I'm trying to implement Creo Schematics into my system. I already have Windchill and Creo Parametric up and running. The problem I am having is getting the viewable and thumbnail to generate for Schematics. I have my preference set to Check In "Models and Viewables".
We are on the following:
CREO View Adapter 3.0 m020
Windchill 10.2 m020
Creo Schematics 3.0 m010
Creo Parametric 2.0 m110
I get the following error in Windchill:
ERROR : wt.wvs.publish.CadConvertECAD Administrator - ECAD Publisher called when no PVZ client side viewable content on EPMDocument.
Any ideas?
Thank you,
Brian
So the answer is that you have to go to the Windchill tab in Schematics and do a Custom Check In. You cannot check it in from the WGM.
