Problems with Radan
Hello Everyone.
We use Creo Elements Pro 5.0 M170, and to create our CNC data we import our Pro-E files into Radan (not sure which version).
Has anyone had problems using this combination? If so, how did you fix them?
Here's what happen, I have 2 different situations.
1)
I start a flat wall, then I create a single flange for its 4 sides. I do this in order to work with the edge overlap feature. I can flatten the part in pro-e and it won't show any problems. When imported to Radan and flattened, the flanges won't show that extra material that makes the sides overlap.
2)
A flat wall has a flange, that flange has added material (with the lenght parameter) and that added material has rounds on its corners. Again, flat pattern looks fine in Pro-E. when imported to Radan and flattened the added material with its rounds disappear.
Has anyone had this problem before?
