[procad] Mechanism Spring
- November 20, 2012
- 1 reply
- 901 views
Mech Warriors
How does one turn on the Spring option in Mechanism?
My Ribbon Applications \ Mechanism does not look like the attached PDF
(Snipping from PTC web site Spring Tutorial)
My Pull Down Insert: Cams, Gears and Belts, (No Springs or Dampers)
Special Config? Special Module?
Creo Elements/Pro 5.0 M110
& CREO 2.0 M020
Win 7 x64
Jscott
This email may contain material that is confidential, privileged and/or attorney work product for the sole use of the intended recipient. Any review, reliance or distribution by others or forwarding without express permission is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
& CREO 2.0 M020
Win 7 x64
Jscott
