ProductView Combined Current Drawing With Out-of-date CAD Models
We recently noted a problem with ProE/ProductView, and I was wondering if anyone else had run across a similar problem.
From a ProE workspace (WF3, m230), a user selected a drawing and it's associated models for check-in. They then logged into PDMLink to verify that their drawing had published correctly in ProductView. However, when they viewed their drawing in ProductView they noticed that the drawing still reflected the OLD version of the model (rather than the version they had just checked in).We tried deleting the representation and re-publishing, but the error would not go away. Finally, we checked-out the drawing, made a change, undid the change, and checked-in the drawing. That triggered another re-publish job for the drawing. When we checked the drawing this time, in ProductView, the error was gone.
This led us to the following conclusion. When a user tries to check-in a drawing and it's corresponding model files all at once, there is a possibility that the drawing can get checked-in <u>just ahead</u> of the models. If this occurs, the drawing MAY latch on to the older version of the model (at least as far as ProductView is concerned). So, even though the drawing may look correct in ProE, it can end up being published incorrectly.To prevent this from occurring, we have instructed our users to check-in all of their model changes prior to checking in the corresponding drawing (i.e.: in two separate operations). We hope that this will prevent any "Race Conditions" and force the drawing to always grab the latest version of the part.
We are using PDMLink 9.0 m060, ProductView 9.0 m090, and PV Adapters 9.1 m020.
Has anyone else experienced this condition? Is anyone aware of any system settings we can implement to guard against this behavior?
Thank you!
SteveThis thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
