8-Gravel
November 2, 2010
ProFileOpen and the mnu-file
  • November 2, 2010
  • 0 replies
  • 655 views
Hello!
I want to open a *.gph file with the ProFileOpen dialog.
It works fine, but is it possible to use the defined "mnu" file in the directory
so thatI got the same dialog like "Insert" "User-Defined Feature..."
Thanks!
Lars
ProPath TheFile;
ProPath DefaultPath = L";
/* No default dirs */
ProPath *path_arr = NULL;
ProName *path_lab_arr = NULL;
err = ProArrayAlloc(0, sizeof(ProPath), 1, (ProArray*)&path_arr);
err = ProArrayAlloc(0, sizeof(ProPath), 1, (ProArray*)&path_lab_arr);
ProName Option = L"pro_group_dir";
ProPath *wValues = NULL;
int nValues;
err = ProConfigoptArrayGet(Option, &wValues);
err = ProArraySizeGet(wValues, &nValues);
if (nValues > 0)
ProWstringCopy(wValues[0], DefaultPath, PRO_VALUE_UNUSED);
err = ProFileOpen(L"Open", L"*.gph", path_arr, path_lab_arr,
DefaultPath, NULL, TheFile);
