Program source parameter
  • August 2, 2014
  • 6 replies
  • 4224 views
I'm trying to change the title block in the drawings from the old engineers name to mine. This is driven by a parameter. When I change the parameter it gets changed back to the old engineers name though(i'm guessing when it gets regenerated).
I looked at the parameter and under the source column it says "program". I'm having trouble figuring out where this parameter is set.
Any help is greatly appreciated.
Best answer by TomD.inPDX
Parametric Gear with Creo Parametric
I have seen files where there is a routine that is activated when you regen. Normally it is used for configurable objects where user input dictates the file configuration. I haven't looked into it much further than that. It has to do with Pro|Program.
To add the engineer's name in such a routine is really kind of dumb. Sometimes people have too much freedom in doing things that are simply not sustainable by the average user.
