PTC_COMMON_NAME in drawing templates
  • May 2, 2011
  • 1095 views
I am planning on moving from drawing formats with mapkeys to add tables and notes for new drawings to the use of template drawings. In starting this move I have run into an issue that I am hoping some of you may be able to help me with. In our formats today we display the value for PTC_COMMON_NAME from the model in the title block of thedrawing but with templates the value for the drawing's PTC_COMMON_NAME is displayed. Has anyone come up with a way to create a drawing from template and have PTC_COMMON_NAME from the model be displayed in the title block?
Thank you in advance,
Scott
Hi Scott,
Using WF5 and WC9.1,
I don't normally use templates but played around with it and found that the
template adds ":D" on the end of the &PTC_COMMON_NAME, making it display
the parameter for the drawing (this is normal behaviour and can be used on
other parameters to pull up the revision number of the drawing instead of
the part for example). If you remove the ":D" after creating your drawing
it works as expected. I don't know how to stop it adding the ":D", I
presume it is being added because when the template is being modified there
is no model to show the parameter of so ProE assumes you must mean the
drawing....
Mark von Huben
