PTC Creo 4.0 tutorial: How to change the default appearance and default background colour
  • November 1, 2017
  • 0 replies
  • 3864 views
Hi, do you like to change default appearance and default background colour for Creo Parametric?
Here is creo tutorial for you:
Create custom colour palette (appearance.dmt) and custom system colour preferences (syscol.scl) and set custom configuration options:
  • pro_colormap_path
  • system_colors_file
... for example:
  • pro_colormap_path C:\config\color
  • system_colors_file C:\config\color\syscol.scl
