6-Contributor
Aug 17, 2026 1:10 PM UTC
Put Today's Date into a new part or assembly parameter's
I have the same request as this thread made a long time ago :
Model Parameter = Today's Date | Community
Anyone out there know how to set a model parameter equal to Today's Date?
Specifically, I'm looking for a way to set the date of a parameter equal to today's date during the creation of a new part or assembly.
There was a proposition to  add the parameter (&todays_date) into your template.
I cannot make a parameter named “&todays_date”
I created a parameter named “DESIGN DATE” with the value “&todays_date” in the part template. When I create a new part with this template, the parameter remains “&todays_date”.
Is it me who does not make this right or is there another way ?
6-Contributor
Aug 17, 2026 1:28 PM UTC
Hi, if using Creo Standalone without a PDM system, there are three options to automate inserting today's date:
* Mapkey + System Command (@SYSTEM): You can record a mapkey that runs a CMD/PowerShell script to capture the operating system date, copy it to the clipboard, and paste it automatically into the parameter field upon opening the file.
* Manual parameter in template files (Start Part / Start Assembly): Define the CREATION_DATE parameter (Date or String type) in the template files. The initial value remains blank or generic, and the designer fills it in when creating the component.
* 2D Drawings (.drw): If the date is needed for a drawing border/title block, you can use the system note &todays_date. When added to the drawing, Creo reads the PC's system date and converts it into static text.
www.altamax-engineering.com
6-Contributor
KenFarley
Aug 17, 2026 2:06 PM UTC
As I understand it, &todays_date is only useful in a drawing template. When it’s in the drawing template it is evaluated once and puts the result into the drawing the template is being used to create. It is not a function or parameter that is available within parts and assemblies.
If I’m wrong about this, anyone feel free to point it out.
The way we get DesignDate (the parameter we use for this in parts and assemblies) is the person creating the part has to input that parameter. Error prone and lacking uniformity (one person might use DD-MM-YY, one use DD/MM/YY, or DD.MM.YY, etc.), but it’s the only way we’ve found to do this. We set it to “-” by default in the part/assembly templates, so it becomes obvious if it hasn’t been set when the drawing creation process is started.
6-Contributor
Aug 18, 2026 9:10 AM UTC
Hi Flolap, yes, the &todays_date is a parameter that works only in drawings.
FLOLAP6-ContributorAuthor
6-Contributor
Aug 17, 2026 5:22 PM UTC
The way we are doing it is like you both mentioned, having a parameter that the designer manually fills when he creates a new part. Its simple and easy but prone to forgetfulness until you make the drawing. &todays_date is used when the drawing is created, generally a few days/weeks later.
​@Massimo Mele, I like your mapkey idea, I will give it a try.
kdirth
Aug 17, 2026 7:13 PM UTC
What is the end result you are looking for?  When the model was created?
Tools > Investigate > File History has info on every save of the model.
KenFarley
Aug 17, 2026 7:35 PM UTC
I believe the OP is trying to automate things so when a user starts a new file, the “date” parameter will be automatically set to the current date. To avoid people forgetting to input the parameter.
6-Contributor
Sep 9, 2026 12:04 PM UTC
Exactly, ​@KenFarley.
So, I created a simple .bat file that copies the current  date in the clipboard :
@echo off
date /t | clip
exit
Then I made a mapkeys that opens de .bat file, create a new file, and once its there, it opens the parameters and paste the date in the “DESIGN DATE” parameter value.
!n3  New Part 3
mapkey n3 @MAPKEY_NAMECreate a new part with today's date;\
mapkey(continued) @MAPKEY_LABELCreate a new part with date;~ Command `ProCmdModelNew` ;\
mapkey(continued) @SYSTEMC:\\Users\\user***\\OneDrive - ***\\PTC\\CREO9\\Setup\\Todays_Date.bat;\
mapkey(continued) @MANUAL_PAUSEEnter File name & Common name;\
mapkey(continued) ~ Activate `new` `OK`;\
mapkey(continued) ~ Command `ProCmdMmParams` ;\
mapkey(continued) ~ Arm `relation_dlg` `ParamsPHLay.ParTable` 2 `rowDESIGN_DATE` `value`;\
mapkey(continued) ~ Disarm `relation_dlg` `ParamsPHLay.ParTable` 2 `rowDESIGN_DATE` `value`;\
mapkey(continued) ~ Select `relation_dlg` `ParamsPHLay.ParTable` 2 `rowDESIGN_DATE` `value`;\
mapkey(continued) ~ Key `relation_dlg` `ParamsPHLay.ParTable` 39190550 `Ctrl+V`;\
mapkey(continued) ~ Activate `relation_dlg` `PB_OK`;
Sep 18, 2026 9:47 AM UTC
Could you please share as to why do you wish to add the parameter?
possible three scenarios would be...
  1. You wish to have it extruded as a feature
  2. you wish to have it as a flat to screen parameter or on a face as an annotation
  3. You wish to know the file history.
I am assuming that you are not using a PLM / PDM software
Knowing, what we know is just a fistful of Earth, brings in humility.
KenFarley
Sep 18, 2026 10:43 AM UTC
If you read all the responses you’ll see this has been answered already.
Sep 21, 2026 4:34 AM UTC
18-Opal
Sep 18, 2026 12:40 PM UTC
Simple solution .. use CREOSON (it is FREE, only requires JLINK to be installed, and works perfectly for this scenario)  You can even wildcard parameter creations and changes - one line -- update everything in session.
Another option would be to use the FREE license of Nitro-CELL to do the same thing - again one line wildcard operation - but from Excel instead of code.  If you go the Nitro-CELL route - there are a bunch of templates out there to reference on GitHub you can download and use for free.
Hope this helps.
Dave
