Question on "owner" ..
  • March 20, 2013
  • 3 replies
  • 1536 views
[I posted this originally in a different forum, I have been told about this forum afterwards... So I am copying and pasting from my earlier posting.
I am reading about "Owners" now in the "help" screens, but I still have not figured out how to create an owner...]
Hello All:
I am a previous Cocreate software user. It has been a while since I did any CAD work.
To refresh my skills and learn the new PTC software, I downloaded the Creo Elemets.
I am not sure if this is the right forum but I ran into an issue that I am not able to figure out.
  • I drew a two-dimensional object --say a rectangle. I am now trying to put dimensions on it:
  • I go to applications tab,
  • Click on "Annotation (click to add)".
  • Click on "New Drawing"
  • Choose w1
I do not know what to enter as the "Owner".
I cannot proceed beyond this.
Any help appreciated.
Deguza
Best answer by DanAdler
You currently only created a Workplane with 2D geometry on it. Annotation is used to dimesion 3D parts/assemblies. If you would like to make a drawing of a rectangle in Annotation you should "Pull" the 2D geometry from w1 to create a box. Next you can create a drawing of the box (p1) in Annotation with just one view of the front of the box.
DanAdler13-AquamarineAnswer
Make sure the geometry on the Workplane is not Construction Geometry. By default Construction Geometry shows up as red dotted lines and actual 2D Geometry as solid black lines. Construction Geometry cannot be used to make 3D parts.
Deguza1-VisitorAuthor
Thank you Daniel.
Now I am struggling with dimensioning
Things are a bit different fro the Cocreate software...
Deguza
