Question regarding Gear Pairs in Mechanism
  • May 22, 2015
  • 7 replies
  • 2773 views
When defining a gear pair, you have to define the pitch circle diameters of both gears. In my case, the connection is a rack and pinion (simulating a pulley/rope train). However, when entering the pitch circle diamater in the gear pair dialog box, I seem to only be able to enter a numerical value. Is there a way to drive that pitch circle diameter from say the base design skeleton (in the context of motion skeleton assemblies)?
David
You can enter a user defined ratio.  In case of the rack and pinion, it want to know a linear distance per rotation.
I have run into some limitations in the rack and pinion where the servo axis has to be perpendicular to the rack.
Differential Drive for Micro-Manipulators
In this mechanism, everything is based on user input gear connections.
dayoub1-VisitorAuthor
Yes, the pulley rotation axis is perpendicular to the slider axis I'm using for the rope.
Is the user defined ratio a parameter that I can drive using a relation? It seems to be simply another way of defining the gear pair. I want to drive that value from another skeleton via a relation.
I haven't tried to find the parameters defined to user-defined gear ratios so I am not sure if it can be driven.
However, you should be able to drive the ratio based on a feature, and the feature can be driven by a relation.
Just not sure how many regens are required to get the new data to take hold.
I went back and looked for the parameter that connects to the gear definition dialog and could not find it.
It seems you should be able to select a feature to set the pitch diameter or drive the value with a relation... but somehow this is buried deep within the code.
I ended up giving up, but now any time the gearing ratio changes, I have to remember to manually update the value so the mechanism still functions properly. Thanks anyways.
If you have maintenance, you can submit a support case to have your question answered.  It may not be the answer you want but it will settle the issue.
In general, a change in ratios also requires a new analysis run.  I agree it should pick up ratios based on geometry or a parameter, but I cannot find how it is done either.
Please report back if you find something that helps.
