Question regarding my assembly and mechanism
  • March 21, 2016
  • 2 replies
  • 985 views
I have a problem with my assembly and I wasn't too sure on how to make it work. For the assembly I would want the 2 struts to be able to move at the same time with a hole in the middle being the connector but i tried using pin connection but I'm still wasn't sure how to make it all fully assembled and stuff. Would anyone be able to take a look at my assembly and help me with it? Thanks!
2-Explorer
March 23, 2016
There is never a guarantee someone will actually look into it and provide a solution.
But from my experience you can increase the chance someone tries it, when you add the assembly (or better a simplified version, showing only the relevant parts) as an attachment (you can do this when switching to the Advanced Editor).
A picture of the situation may be another way to raise more interest.
Gunter
...or the discussion fell off the bottom of the page and didn't get noticed.
If you go to the advanced post editor, you can attach files.  It is best to save-as or backup as a zip file to make sure everything required is captured.
You can copy/paste images in the forum.  There is no longer the need to save the image and link it here.
