Rectangular Fill Pattern Capability
I am trying to fill an area defined by a circle with a repeated component in an assembly. I would like to use the square fill pattern tool to do this. The diameter of the circle is driven by a relation and it is not static, so the fill function seems to be the best choice rather than dimension or direction patterning. The problem is that I need different spacing in each planar direction. I've looked at previous discussion threads and the issue was not solved. I've tried all the patterning tricks I know, and I cannot get the fill pattern I need.
