2-Explorer
July 10, 2015
Reference Balloon [How to set different Item Numbers]
  • July 10, 2015
  • 2 replies
  • 3868 views
One can change drawing properties option "reference_bom_balloon_text" which allows user to have different text for reference Balloon. Along with this, I would like to update item number inside this which seems impossible as rpt.index cannot be overwritten.
So, I would like to understand how one can change symbol being called when user clicks on Create Ref Balloons into drawing file.
Thanks in advance...
Regards
Ketan
KenFarley
The easiest way I have found to change the number of an item in the bill of materials is to re-order the items in the assembly. Easy enough as long as you do not have any dependencies among the components you want to move.
If you do a search engine inquiry with something like "Creo change order of items in bill of materials", you find that a possibility might be to use the
Table -> Repeat Region -> Fix Index
I've not used it but messages seem to indicate that this might be what you're looking for.
2-Explorer
July 10, 2015
Thanks...sorry for not providing enough information.
My bom table item number are not matching with creo default item number(RPT.index)...bom is having custom numbers and same I would like to use for reference BOM
