regeneration of parts &assembly is slow in creo 3.0
  • August 19, 2015
  • 3 replies
  • 3119 views
i just want to know whether the regenaration in creo 3.0 is very slow or even the system get stuck while do regenaration,intially i thought it was for complex assy but even for the part it is very slow.
is it happening for all???
can you upload some part and defined, what you want to test ?
Martin Hanak
18-Opal
August 19, 2015
Hi Dinesh,
I agree with Martin.  It would be helpful to have some additional information on what you are seeing, in terms of slow regeneration.
It could be caused by the machine configuration, if it is not certified and supported for Creo 3.0 or it could also be model specific.
Amit
Dale_Rosema
mrd10-MarbleAuthor
can u pls let me know which config will creo 3.0 work faster
Hi Dinesh,
Still you have this issue...
