Relation Table patterns
  • April 22, 2016
  • 2 replies
  • 1490 views
I would like know if it's possible to change the pattern table with a relation.
For exemple. I make a pattern by table for an Extrusion_1 and i create 2 tables.
Pattern Table 1= Table_A
    id1  d0=20
    id2  d0=30
    id3  d0=40
Pattern Table 2= Table_B
    id1  d0=20
    id2  d0=30
    id3  d0=40
    id4  d0=50
    id5  d0=60
I search a relation of this type.
/* Pattern of Extruction_1 with Table 1
if AAA=="TRUE"
table_pattern:ID_EXTRUSION_1="table_A"
endif
/* Pattern of Extruction_1 with Table 2
if AAA=="FALSE"
table_pattern:ID_EXTRUSION_1="table_B"
endif
I don't know the exactly term of "table_pattern:ID_EXTRUSION_1". If there exist.
Thank for your help,
Damien,
Pro/Program can suppress or unsuppress features based on a condition. So you might need to have two features in your model instead of just one Extrude.
Try digging into the PTC Creo | Help Centers
Good luck.
you can switch between pattern tables, if you create family table in your part.
MH
