Remove section from Rib.
  • April 24, 2018
  • 1026 views
I want to remove section from rib. But I don't get any proper solution.
I did search in Google  and get some solutions but it is not perfect.
One is , By creating sketch with use edge, it is not possible to manage the changes in model.
Another is, exclude the rib in representation. if I will exclude the Rib then radii. will also get suppressed. so again it is not useful.
Why PTC don't add simple solution? Like in the Rib command there should be simple option for cross section.
It is difficult to understand your problem.  Can you upload a model or share some screenshots that show what you are trying to do?  That will help us help you find a solution.
