8-Gravel
August 8, 2018
Remove Symbols
  • August 8, 2018
  • 6 replies
  • 3196 views
I am looking to remove certain symbols from the default menu.
I almost always only use Diameter and Depth and it can be quite cumbersome looking for them in the menu when I want to add them to a dimension.
Is there a way tor reduce how many are available?
kdirth
Right click on the ribbon and select "Customize the Ribbon".  You can now add, remove, rearrange commands.
MDrake8-GravelAuthor
8-Gravel
August 8, 2018
I'm not looking to remove the symbols button.  I am more looking to either rearrange the default symbols or remove most of them so that I can easily find the two that I use most often.
kdirth
This will allow you to rearrange the symbols, move them in and out of sub menus (using the arrows on the left side of the window), and add or remove symbols as needed (using the arrows in the middle of the window).
