Removing material in an assembly
I have an assembly with various parts. I have a perimeter with parts that go past that point that I want to use an extrude for example and cut the excess material away so I can get a nice clean edge. When I do that it says my sketch is outside the model. What's the easiest way to remove material like this...taking away material from various parts?
