repeat a Geo Tol in a drawing
It would be useful if we could repeat a Geo Tol in a drawing without always starting with the simple "tolerance of precision" I seem to remember in the past when it would start with the previous instance.
These are in the drawing, not the model. I sincerely hope that's not the problem. In fact that couldn't be the
problem because if they were "in the model" they would simply "show" I would rather add the tolerances in the drawings.
Mfridman
MfridmanAnswer
Hi @vincecatlin ,
We already have a solution for this request 🙂
Please try to set the following config.pro option: attach_last_gtol_to_cursor yes
When placing a new gtol instance, this option will use the last used gtol type with all of the used values and properties. It works in the same way for MBD, as well as for drawings.
Best Regards,
Michael Fridman
Creo Product Manager
Mfridman
Mfridman16-PearlAnswer
Hi @vincecatlin ,
Best Regards,
Michael Fridman
Wow, that is exactly what I was wanting. Thanks Michael.
Mfridman
Glad that I could help 😀
Michael
