Repeat Region Not Correct
  • July 3, 2014
  • 0 replies
  • 470 views
WF4, M220
I have a simple assy drawing with a repeat region table. The table is set to no duplicates / flat / Bln By Part / No Cble Info.
The assy has 6 components:
  *   Part
  *   Subassy
  *   Screw
  *   Screw
  *   Screw
  *   Screw
The screws are all the same, so I should have 3 lines in my table.  When I created it, I did.  I went to update the drawing today, and none of the parts have changed, but the line for the first part is gone.  The table shows only 2 lines, the sub assy and the screw.
There are no filters, clear all is greyed out and selecting edit brings up a blank window.
I tried changing the attributes and by allowing duplicates, my part shows up (along with 4 lines of screws), but going back to no duplicates it goes away again.  Flat vs. recursive does not help, balloon by part or component doesn't either.
How do I fix this?
