repeat regions question
  • February 10, 2010
  • 539 views
Good morning,
I am trying to create a table inside of an assembly drawing and
would like to pull parameters from parts to fill out the table. I can not
remember how to pull parameters from a part while creating a table in an
assembly.
Example: I have a parameter in the part called "thickness" and it has a
value. I need the value to show up in my table inside the assembly.
Thanks.
Son Nguyen
785-667-7763
108 W. 2nd Street
Assaria, Kansas 67416
if you are referring to a BOM type of table with a repeat region assigned,
your table entry would look like this &asm.mbr.thickness
Bob Frindt
Sr. Designer
Parker Hannifin Corporation
Parker Aerospace
Gas Turbine Fuel Systems Division
9200 Tyler Boulevard
Mentor, OH 44060 USA
direct (440) 954-8159
