Replace Fitting
  • July 25, 2019
  • 1218 views
hi all,
How can I replace a fitting by pipe diaemeter? I can't find the relection using pro/program
@IF_01  -
It is going to be very difficult (if not inmpossible) to change a CAD model for the fitting in your pipeline based on the diameter of a pipe in "normal piping." The way to adjust this fitting per the diameter or "size" of the pipe would be to use spec driven piping. If you aren't familiar, check out a blog post that we wrote here:    https://cadactive.com/blog/2018/01/03/spec-driven-piping/
And another here: https://cadactive.com/blog/2018/04/11/standardizing-spec-driven-fittings/
Hope this helps!
