Restricted parameter and relation
I have a parameter (string) controlled by an external file ( using restricted_val_definition option ).
No problem if I change the parameter value directly using the drop-down menu in the parameter panel.
But if I change the value in "Relation panel" for special conditions
IF ...
parameter_name =="value"
ENDIF
ProE doesn't change the parameter and an error comes up !
The name "value" is typed correctly .
Same problem with other types of Parameters (number ,...)
I tried with WF5 and Creo1.
Any idea ?
Thanks a lot
Pier
