REVISION MANAGER
  • July 14, 2018
  • 5 replies
  • 4051 views
Hi ,
Is there any option in Cre-o to save an assembly into desired folder without using save as option.
Similar to Revision Manager in Solid Edge Software.
in case that you created new assembly Creo will suggest you to save it into current working directory. You can change target directory.
mekins1-VisitorAuthor
Dear Martin ,
If I have created many parts , in  which some of the parts are not used while creating Assembly.
Then how can I save that Assembly to separate folder without using save as option.
Regards
Raghu
unfortunatelly I do not understand what you need. Please provide more detailed explanation.
