round a dimension in a drawing
  • May 20, 2018
  • 2 replies
  • 1506 views
how i can round up to the closer moultiple of 250 in a drawing?
Thanks!
Since I dislike rounded dimensions greater than the least significant digit...............
Change your model so your dimensions are all multiples of .250!
Change your dimensioning to be fractions and then use 4 as the denominator.
The drawing SHOULD reflect the model.
PHABIO1-VisitorAuthor
Thanks but I don't round up by multiple of .25 mm,
I must round up by multiple of 10 mm (250 is for example) so I can't use your solution.
I don't like rounded dimensions but I must do it for presentation to bourou of Italian MInister of Trasport.
I work by mm, they no! (sob)
