Running mapkey on all instances of famtab
Hello all,
I have made a verry nice family table with different trajectories on part level. I also made a family table of an assemblycontaining the trajectory part and a part thats running over this trajectory using mechanism constraints.
I also made a mapkey to run an analysis in mechanism-modeand using the result to make a motion envelope part. This is working perfect! (I was amazed that this could be done)
The next and last step for me is to run the mapkey on all assembly instances (150) and creating the 150 motion-envelope parts. I tried using Sbatch (great tool) but I cannot select instances with this program.
who knows a trick for me to dothis?
A workaround could also be to transform all the instances to single non-famtab parts? Can this be done?
Kind regards,
Dennis Varkevisser
Dennis Varkevisser
Flexible Engineering Support
<u>www.flexibleengineeringsupport.nl
+31 6 50 68 01 79
</u>
