Screenshots inside Creo
  • March 6, 2018
  • 29 replies
  • 10422 views
Greetings all.
Does anybody know if there is a way to take a screenshot inside of Creo within a window? I currently use the printscreen button and paste it into Paint. I then select the area I want and put that in an email. I am looking for a way to select a window in Creo and paste that into an email without having to use Paint.
Thank you in advance for your assistance.
Best answer by wjahr
Then I'll go for a "reconciliation post" as answer, because it's probably least confusing in the unlikely case anyone happens to stumble across this 🙂
The workflow that works for me now:
I am creating auxiliary datum planes in each component that correspond to the positions of the "optically relevant" planes. These planes are the ones that would have to coincide if the microscope was build straight, and the distances of these planes will also be used to lock all of the relationships.
The folding mirrors will realistically be placed under an angle of 45 degrees only, so I'm creating auxiliary planes as well that correspond to the planes that the light path is located in before and after the reflection off the mirror. Since the mirror is at 45 degree, these planes will be at 90 degree to each other (and 45 degree to the mirror).
The distance between the relevant optical plane of the component just prior to the folding mirror, and the relevant plane in the mirror is then defined when setting the constraints during placement. The distance between mirror and the component behind the mirror has to be the negative of the distance in the first constraint, and so on, through the whole assembly.
The positive and negative distances are linked by defining
$dist_neg = - dist_pos
in the relations window.
It of course helps to rename the distances first: This can be done eg. by editing the feature (right-click in the feature tree and select the icon with the distance pictogram), then selecting the distance (it has to turn from yellow to red) and then right clicking to select "Properties".
You can certainly use relations to set certain dimension values equal to something but I wonder if maybe mechanism connections would work better.  You could make extra parts to represent the optical distance and then constrain the mirrors and these path parts with pin connections.  This would allow you to move around the mirrors while always keeping them a fixed distance from each other (whatever length the distance parts are set to.)
wjahr1-VisitorAuthor
The way I understand it, a pin connection would keep two points fixed to each other, but they could still swivel around one axis. That would certainly help to "pin" the light path to the mirror surface while the mirror is tilted, but could the optical path slide along the mirror when the mirror is moved?
Maybe a good mechanical analogon would be a rope of a fixed length that has both endpoints held fixed. The mirror surfaces would be like hooks that the rope can bend around/slide across as you change the position of the hooks/mirrors - while the endpoints stay fixed at all times.
PS: Please bear with me, I'm a complete noob using Creo, and the transition from Solidworks is harder than I had hoped ...
I would create a set of datum curves to represent the ray of light that is in the center of the optical path and use relations to control the path lengths. If these curves were in a skeleton part, the skeleton can be added to parts and sub assemblies as construction references to ensure consistency.
Since Dassault has put the Solidworks help files on line, perhaps you can point to the functions/features you would have used to create this. http://help.solidworks.com/2018/english/SolidWorks/sldworks/c_solidworks_fundamentals_overview.htm
